03-12-2017, 05:20 PM #1
- Mar 2017
Monoprice Select Mini Z axis problem
Been using my 3d printer for months with no serious issues, minus some clogging. I printed off some mods and replaced the hotend with e3d with zero offset. While inside I added a second fan (1 for hotend, 1 for part cooling). Also added the z axis base stabilizers. After I reassembled the printer my Z axis is not working.
I removed the threaded rod and checked the motor. It turns on but seems to go in only 1 direction.
So, I'm guessing I have extra tension prevent from the threaded rod from spinning loosely? But don't understand the single direction. Need help. Any ideas?
03-13-2017, 11:23 AM #2
03-13-2017, 12:26 PM #3
- Mar 2017
Removed the motor completely. The motor works but only 1 direction
