Results 1 to 9 of 9
02-13-2017, 06:01 AM #1
- Feb 2017
- 9
Buying a 3d printer looking for advice on dependability.
I am looking at a lulzbot mini because the size meets what I need. I own a small at home cnc machine and would like to be able after modeling being ablt to print the part up for a check with the customer before putting a lot of machine time into the part. Is the lulzbot mini dependable? It will sit long periods of time. I am not new to 3d printing just new to this type of machine.
02-13-2017, 07:00 AM #2
lulzbots generally get good reviews, about all I can say really.
02-13-2017, 07:35 AM #3
- Feb 2017
- 9
Are you using a system that has been dependable? I am not stuck on lulzbot I just want something that will do the job at a good price.
02-13-2017, 09:08 AM #4
May I suggest you take a look at our Fusion3 F400-S? Its built for greater reliability / dependability, comes with 2 year warranty and free lifetime technical service & support.
02-13-2017, 09:56 AM #5
- Feb 2017
- 9
I am not stuck on any particular machine I am more in hope enough people on here will steer me in the right direction, But that machine you are talking about is over 4 grand I am looking at a 1200 dollar machine range.
02-13-2017, 10:18 AM #6
MY flashforge creator has been in operation for 3 years. Apart from tiny amount of routine maintenance (bolt tighten, rod clean and lube) not had an issue with it that I couldn't trace directly back to something I did wrong.
About 1200 printing hours on it. So yeah seriousuly reliable. Moved on/off switcn to front, added print area cooling ducts. Apart from that all parts are still factory original.
It's an old model these days - so not huge build volume: 220x150x145 mm basically 9x6x6 inches. I have yet to need anything bigger.
Flashforge only do the creator pro these days and I'd probably take it over any of their newer models.
the qidi version: https://www.amazon.com/TECHNOLOGY-3D...&keywords=qidi
Gets good reviews and has plenty support.
What's your budget ?
02-13-2017, 10:58 AM #7
- Feb 2017
- 9
I don't need a dual extruder. But the price is great. I will research these a bit more.
02-14-2017, 07:15 AM #8
- Feb 2017
I think that might be helpful to this article best cheap 3d printer under 500
I hope that I may be able to inform you
02-14-2017, 09:04 AM #9
- Feb 2017
- 9
I am looking in the $1200. range
New member with print issue
Today, 08:57 AM in Tips, Tricks and Tech Help
