Thread: Stuck filament
01-27-2017, 10:44 PM #1
- Jan 2017
- 10
Stuck filament
Hello everyone, I had an earlier problem that is now fixed, but just ran into another. While changing filament in the right extruder, the filament broke right at the top of the extruder making it impossible to even get some needle nose pliers to grab the filament. I thought that I could just load some new filament and push the old through. That didn't work, seems like I got a pretty good jam near the top. I tried removing the nozzle and tube to somehow get the filament through with no luck. Is there anyway to get into the top of the extruder? Or maybe an easier, better way? Thanks for your help.
01-28-2017, 06:51 AM #2
- Apr 2015
- Northern Ohio
- 198
What printer? With the nozzle and the PTFE tube out it should come right out.
01-29-2017, 10:34 AM #3
- Apr 2016
- 120
The whole assembly can be taken apart quite easily.
Remove the allen keys holding the fan in place, remove the cable connector from the top of the stepper motor and gently pull the motor from the back of the block.
The extruder will then be able to be pulled out and you can even disassemble this if required.
01-29-2017, 06:25 PM #4
- Jan 2017
- 10
Thanks Todd-67 and noiseboy72.
I figured it out, didn't know about getting to the feeder by removing the fan.
