Results 1 to 10 of 16
Thread: Gear material
01-09-2017, 05:42 AM #4
pla is also good for gears, you just need to bear in mind that most fdm plastics soften at around the 60-70c temperature zone.
If you have an all metal hotend and a heated, enclosed print volume, and can afford peek - you can up the working temp to over 100c.
