Results 1 to 10 of 10
01-02-2017, 01:41 PM #1
- Jan 2017
- 6
3D Printer not responding after some minutes
Hello,
I have a Solidoodle 4 3D-Printer and it has been working normally until now.
Everytime I connect to the printer via Pronterface or Repetier Host, everthing works for a minute or two. But then it stops and doesn't respond anymore. The only way I can get it to work again is cutting the power to the printer and reconnecting it.
Why does it alway stop to respond?
01-02-2017, 02:00 PM #2
- Apr 2016
- 120
Try uninstalling and reinstalling the drivers. Also worth checking for any updates and make sure that Windows has not done an update and broken things!
01-02-2017, 02:15 PM #3
- Jan 2017
- 6
Thanks for the quick reply, but after reinstallation of the drivers the problem is still existent.
And Windows Update is disabled.
01-03-2017, 02:32 PM #4
- Apr 2016
- 120
Might be worth a chat with the makers then. Could be a power supply fault I guess?
01-03-2017, 02:45 PM #5
- Jan 2017
- 6
Unfortunately, the company has suspended operations...
01-05-2017, 02:54 AM #6
I think maybe the power is not enough, you can try test the output voltage
www.reprapmall.com
01-05-2017, 04:55 AM #7
- Jan 2017
- 6
Could it be an issue, that the printer is plugged in into a power strip and not a standalone power outlet?
01-05-2017, 05:23 AM #8
- Sep 2016
I don't really think that should be the problem. But it's worth the try a standalone power outlet if it's possible.
01-05-2017, 05:33 AM #9
- Jan 2017
- 6
I will try that as soon as I get home
01-16-2017, 11:48 AM #10
- Jan 2017
- 6
