Results 11 to 14 of 14
Thread: Bismarck Scale Model 1:100
12-02-2016, 08:45 PM #11
- Oct 2016
- 12
Hi All
Needing some advice, I am finding my PLA hull very hard to sand as its heating up too much as I am using a small mouse sander due to the size of the hull.
Is there a better way to finish, I was thinking about building up several layers of filler primer and sanding the filler down until I have a smooth hull, has anyone done it this way?
Cheers
Druid
12-03-2016, 02:27 PM #12
- Oct 2016
- 12
Hey All
Just a quick update spent a few hours sanding and spraying a filler primer just to get a rough indication on whats needed for a smooth finish, there are a few areas that needs attention, I think its going to take several laters of sanding and filling for a good finish.
http://i103.photobucket.com/albums/m...psayjvonpq.jpg
As you can see I had to buy a work bench to work my model on
Druid
12-31-2016, 08:22 AM #13
- Oct 2016
- 12
Hi All
Sorry for no updates recently, unfortunately my A8 is out of order at the moment, my X Axis stepper motor developed a fault and I am still waiting on a replacement for it under warranty, hopefully it is on its way but the message from GearBest was a little cryptic as all I got from them was that customs in the UK may open the package so I assume they have sent me something.
Cheers
Druid
01-02-2017, 05:32 PM #14
- Oct 2016
- 12
Hi All
Since I am still waiting on the parts to fix my 3D printer I decided to work on the deck of the ship, at first I was going to 3D print all the decking boards but as I wanted to get moving on something I have decided to wood plank the deck, well that was until I started doing it. I found some scrap wood lying around and using a Stanley blade I cut these into strips for the individual planks.
This is extremely tedious work and I cant cut straight, lol. Some sanding will be required, here is around 3 hours work between cutting and gluing and its barley touched the deck.
http://i103.photobucket.com/albums/m...ps6vn0y0qj.jpg
http://i103.photobucket.com/albums/m...psmmmgvmnj.jpg
Cheers
Druid
New member with print issue
