Results 1 to 8 of 8
12-30-2016, 02:54 PM #4
A handy g-code reference is on the reprap wiki at http://reprap.org/wiki/G-code
The following assumes your printer is running Marlin firmware.
The key setting to check would be the parameter that is in the configuration.h file for the Z term in DEFAULT_AXIS_STEPS_PER_UNIT. This is accessible from your host software by sending your printer an M92 command. It is also accessible via the LCD via CONTROL | MOTION | zsteps/mm. The correct value would depend on the nature of your hardware. Are those M8 threaded rods on your z-axis? If so, the correct value should be 2560 steps/mm per the Prusa calculator.Last edited by printbus; 12-31-2016 at 05:34 PM. Reason: corrected the label for the configuration.h term
