Results 1 to 10 of 11
Thread: I really need some help!
12-29-2016, 06:24 PM #10
- Dec 2016
I already installed the profiles for every program/slicer they had profile for.
Once again i am telling you that nothing was change from previous print 100% perfect print VS next print next day total failure and the print after that witch was something i already printed and worked really well now not even close.
I see the stats of the printer on the display and nothing is changing also the temps are steady both extruder / hot bed.
I also installed drivers but not the drivers are the issue.
I also updated my motherboard bios and installed all the USB related drivers from ASUS also the Chipset.
Nothing works (even with no hub straight connection i get the same issue)
This is not on a single pc/laptop (1 lap / 1 pc ) 2 different OS.
Tested all ports on both.
