06-30-2016, 01:14 PM #1
- Jun 2016
Cheap 3D Printer in Asia - Cubicon 3D printer 3DP-110F(Single)
First Domestically Designed Replaceable Extruder
The extruder is an important critical component of the FFF-type printer, as it fuses and fabricates the filament.
Cubicon Single is the first product in Korea to design and mount its own replaceable extruder. With our extruder, we help you create optimized printing environments. Just exchange the extruder when using various types of filaments. When the nozzle gets blocked, you only need to remove the part that’s giving you trouble. We have done all we can to make your printing experience as easy and pleasant as possible.
Since FFF printers melt material for printing, the quality of the final product is affected by the surrounding environment. Therefore the temperature circulation features of our printers have an impact on the printing quality.
Cubicon Single has implemented a convection feature that maintains the temperature inside the printer at a constant rate. Consequently, this feature prevents the product from warping.
To ensure user safety, the convection feature can also quickly lower the internal printer temperature to the outside temperature after printing has been completed.
First in the World to Apply bed with Auto Leveling Plus Function
The leveling of the heat bed?the platform for printing models?and its distance from the nozzle are significant factors that determine the printing quality. Until now, most FFF-type printers have resorted to a manual adjustment of the bed level by the user because the Auto Leveling features employed so far by some printers were not completely automatic as they were not supported by software.
The Auto Leveling Plus feature that Cubicon Single has developed performs precision measurement of the heat bed level for all printing. Thus, the space between the nozzle and the heat bed is adjusted automatically and maintained at the most optimal distance.
Furthermore, we have applied special coating to the heat bed. You no longer have the trouble of applying kapton tape to the bed. Less trouble, Better quality!
First in Korea to Mount Clean Filters : your Health is Also in Our Interest
HEPA Filter : H13 HEPA class, removes at least 99.97% of airborne
particles 0.3 μm in diameter
Deodorizing filter : filters harmful gases
Purafil catalyst : filters organic compounds generated from copy printers
Ergonomic and Stylish Design + Easy-to-Use
Cubicon Single has implemented a familiar design for our printers that will fit right into your office space. The dial button in the control panel allows you to control our printers with ease.
Read More: may in 3D
3D SMART SOLUTIONS COMPANY LIMITED
Email: info@3dss.vn (24/7)
10-17-2016, 05:35 AM #2
3D LED Printer
UV LED Printer.com Provide services for UV LED technology based printing machines that can print on a variety of surfaces including 3D objects based in Singapore we provide Specially Printers and wide range of customers in South-East Asia.
