Results 11 to 15 of 15
03-02-2014, 02:44 PM #11
03-02-2014, 07:03 PM #12
DrLuigi,
Where do you put your multimeter probes to get the stepper driver output voltage?
OME
03-02-2014, 09:17 PM #13
03-04-2014, 11:56 AM #14
- Feb 2014
- 13
03-04-2014, 12:53 PM #15
I would highly suggest to take a look at those stepper drivers,
As they can be a bit to much/to low.
Doing this without a multimeter is quiet bad imo,
I noticed that even the slightest turn can make 0.4-5 diffrence easily without you knowing it,
And i had skipping when i was at 0.37.
Might test later on today on a dry run if it would happen again or not.
Probably i will just keep it at Z1 and repeat x50 y50 x150 y50 and make quick squares, So i can see if it has skipped.Last edited by DrLuigi; 03-04-2014 at 01:04 PM.
New member with print issue
