05-28-2017, 10:00 PM #1
- May 2017
- Carlsbad, CA
Outer perimeter different sizes (Monoprice Maker Ultimate/Wanhao Duplicator 6)
I'm printing this out of ABS:
https://www.thingiverse.com/thing:1664313
I'm using Simplify3D as my slicer.
Print temp: 225C
Bed temp: 100C
Infill: 50%
Any ideas on why this might be happening?
06-21-2017, 06:42 AM #2
My suggestion is to lower the bed temp below the glass transition point of ABS (100C), and turn up the fans a bit. It can be that you are slightly overextruding and the extra pressure makes the structure buckle.
06-21-2017, 03:13 PM #3
Not only that, but you can see the bottom of the model has "elephants toes", where it is slowly spreading out over the heated bed.
06-22-2017, 06:32 AM #4
Also if you have a tight calibration the bottom layer get's 'smushed'.
I usually do this deliberately, for things that need extra stick and file the lip off.
Abs comes into the category of 'things that need extra stick' :-)
The recommended temp for abs bed is 90c.
