Results 1 to 10 of 10
Thread: Blue tape width
Hybrid View
01-13-2015, 10:57 AM #1
- Jan 2015
- 2
Blue tape width
I am trying to find a wider width blue tape, just so I don't have to put multiple strips down. I haven't had much luck.
Has anyone else find them?
If you did, what widths did it come in?
What widths would be useful for everyday use?
01-13-2015, 12:09 PM #2
I find it cheaper per square inch to buy the 3in rolls, but 6in wide rolls are available.
01-14-2015, 07:50 PM #3
Something to point out. Masking tape out gasses. Locals around these parts recomended that I store tape in a plastic zip loc bag and away from sunlight. I have masking tape for automotive at 2 inches wide that still works perfectly. I use it when I do machine work and dont want the jaws damaging the work surface.
01-15-2015, 10:18 AM #4
- It depends on how fast you go through it, if your tape rolls last you longer than a month then sealing them after use is good practice. Otherwise there isn't enough time for the tape to degrade in the open air. I go through 1-2 rolls a month, so sealing them isn't necessary.
- I found regular masking tape not to be as effective as painter's tape, is the automotive masking tape similar to painter's tape? Would you have a link to some?
01-15-2015, 10:26 AM #5
here's a question. I currently use 1 inch tape. On the grounds that it's easier to repair holes. Plus the bed is 6 inches wide.
But does the wider 3 or 6 inch tape give you better adhesion to the bed ? Ie: stop the print warping more than it does with the narrow stuff ?
01-15-2015, 12:11 PM #6
- I found that the wider the better, not only for adhesion but its also easier to apply. If properly applied (using a credit card or something similar to firmly adhere it to the bed) any size tape works.
- Its true you can print directly on the bed, but I found it was extremely difficult to remove the parts sometimes. I find it much easier to just peal the tape & part off as one; then I peal back the tape off the part. I print a lot of parts all day every day, so even though its not very cost effective I find it a much faster process for getting the next part started.
- Thanks for the tip. The cost is a little over double in comparison to the standard blue, but if the adhesion is better it might pay to use this with my more troublesome filaments.
01-15-2015, 10:29 AM #7
What are you folks printing in, that you need the tape? I print PLA right on the glass at 40C.
01-15-2015, 10:35 AM #8
- Oct 2013
- new jersey
- 752
Automotive tape is painters tape but the adhesive is a touch stronger plus its solvent base adhesive not latex. The tape resists solvent based paints. Nit that i use tape often for printing but when i do it is automotive grade tape. The tape you want is 3m 233+. Its green. 3m also has their mid grade automotive refinish tape which is bright yellow.
01-15-2015, 10:41 AM #9
don't have a thick glass bed. I get free (well I give them telephone and teamviewer support and they give me aluminium) aluminium plates, so not bothered with spending money on thick glass.
Hence the need for some tape :-)
01-19-2015, 04:41 PM #10
- Jan 2015
- 2
Thank you for all the feedback.
I did find a 6" width tape supplier. It should be delivered on Friday. After I run some prints, I will report.
Yesterday, 12:15 PM in 3D Printer Parts, Filament & Materials
