Results 1 to 10 of 48
11-23-2014, 03:24 PM #1
Everything's tight. I's just come out of the shop from its 10,000 mm extrusion service.
Dr Luigi may have hit on the cause - room temperature too high. Roxy, what is the room temperature you are working at when you get your jumps? I was sitting in 36C without A/C, and 33% humidity.
My steppers were pretty hot, but there were no unusual clicking sounds. That is to say, the steppers were not clicking, which is usual for my printer.
If my belts were loose, or the steppers were missing steps, how do you explain the exact amount of displacement of the Y axis?
Old Man Emu
11-23-2014, 04:31 PM #2
You should be good for 10,000,000mm of extrusion service. Each 1Kg roll (at 3mm) is about 100 m. So 100 rolls is 10^7 mm.
My room temperature is usually between 65 F and 75 F. It is more the bed temperature that affects my jumps. The bed gets hot enough to print, but it isn't really up to full temperature until I've been printing for 20 minutes. And then, it is probably a number of things factoring in. The bed and all the mounting hardware is getting warmer. But also, the thing I'm printing is getting higher up off the bed which means any curling up edge presses harder on the nozzle when you go across it. At some point, it is enough of a curl and enough leverage (because it is up above the bed) to click it back to where it wants to normally be. If you don't have a spring mounted bed, this is just an interesting anomaly for you.
11-25-2014, 09:43 AM #3
When the new motors started being used by MakerFarm, little data was found for them. The manufacturer doesn't do a good job publishing data for every one of their motors.
Any of a number of NEMA17 stepper motors would work fine. I replaced just the extruder motor with a Kysan 1124090 I got from eBay. Kysan appears to be one of the premier brands for stepper motors, a number of people use the 1124090 on repraps, and it met the specs called out in the reprap wiki. When I want to invest more in my April 2014 era printer, I'll order more motors and swap out the rest.
Here, the OP is in troubleshooting mode. Colin continued to empahsize that the motors running hot were not an issue, but some of us haven't been convinced. Most of us have gobs of fans laying around from computers and what not. Experimenting with more airflow on a motor is something that can often be implemented in a few minutes. If testing concludes that the motor temperature is related to the problem, then the decision can be made on formal implementation of the cooling fan as a permanent bandaid or motor replacement.
11-25-2014, 03:18 PM #4
11-25-2014, 03:31 PM #5
I bought one from the 3dmakerworld seller. Their picture doesn't show a Kysan sticker, but the motor came with one. Although I do have to chuckle - it looked like a label anyone could have printed and stuck on the motor.
These motors all tend to look the same, but one obvious thing about this one I found impressive is the wire gauge. It's marked #22, compared to the #26 wires on the OEM motors from MakerFarm. Heftier wire should mean less resistance, leading to more power being applied directly to the motor. I'm not sure that difference in the motor specs alone would have justified the increase in wire size for the Kysan.Last edited by printbus; 11-25-2014 at 03:42 PM. Reason: picture of 3dmakerworld Kysan motor added
11-26-2014, 07:59 AM #6
Great! Thanks printbus, it looks like I'm going to be ordering a few of these. I was finally able to get the print I was having trouble with to complete successfully!
The solution was to set up a fan similar to how AbuMaia suggested. It kept the the motor much cooler in comparison to the extruder. Another thing I think helped was tightening the y belt down as tight as I could. I suspect the heating of the motor was the true culprit of this issue though!
Thank you all! OME I hope these suggestions are helpful for you!
11-27-2014, 03:27 PM #7
UPDATE:
I did the prints last night - it's nearly 8:30 am as I write this, you sleepy heads - and the jump did not happen. The ambient room temperature was 21C.
I think I might put my money on "Overheated Y Stepper" to win the Reason Stakes and bring a fan when the temperature out in the field is over 30C.
OME
11-26-2014, 08:40 PM #8
I think you blokes have missed something. You are concentrating on the temperature of the Y axis stepper. You forget that at the same time as the Y axis stepper was working flat out, the X axis one was working just as hard, and without error.
The other thing is, if the belt or pulley was loose, then subsequent layers would not be printed accurately on top of the preceding oout of position one.
Old Man Emu
