Originally Posted by
jsondag
I think you may be going about it the wrong way. The water itself should act as one electrode. I think a fairly usable capacitor could be made using a strip of copper foil, as one capacitor plate, along the inside wall of your build container, insulated from the water, perhaps with some kapton tape, or laquer, making sure to get a good seal around it. For the other "plate", place an electrode that won't corrode, close alongside it in direct electrical contact to the water all the way to the bottom. The water would be salinated, which of course it needs to be for the peachy anyway.
I don't beleive the salt level will matter much as you'd be relying on the capacitance, which is based on the thickness, and dielectric constant of what you use to insulate the strip. It should be unaffected by temperature, or resistance of the water. You could simply use this as the capacitor in a 555 timer based oscillator (astable multivibrator) if you keep it in the audio range you can read it on the mic input of a sound card. Sound cards are very good with frequency accuracy.
I could whip something up. I've been thinking about it a while, I've just been lazy and unmotivated :-P
