04-22-2024, 01:20 PM #1
- Mar 2024
- 8
Hi again
Sorry for the above post.. It was obvious that I hadnt looked at the settings for the resin. I have now set them as advised to - Bottom Exposure: ~60s; Normal Exposure: ~8s but even with this I was still getting a similar problem! However, I have managed to get one out of three prints which stayed stuck to the base plate
I am trying to print a flat peice (see pic) with holes in it which are 0.8mm 1mm, 1.4mm & 1.8mm
This print though has srinkage which i am working on fixing through changing the dimensions of the holes using tinkercad before printing
is it normal for what I am trying to do to have the holes filled in with cured resin just on the surface and is there a solution to this
The other thing even though the print stayed stuck to the base plate it seems warped on the edges even though the holes are stright
I am just a newbie.. please !! anyone with any advice very much appreciated!
