Thread: Red LED light on the Printrboard
01-03-2015, 01:16 AM #1
- Jan 2015
Hi everyone, I just finished building my Two-Up printer and plugged in the power cord. I got the green LED on the power supply and the red LED on the red PCB, sound like this is normal. Next I plugged the USB cable into my Windows 7 PC and it detected the device but failed to load any drivers. I tried connecting it to my Mac and didn't see any indication that the Mac saw the device at all. What am I missing?
01-06-2015, 03:49 PM #2
- Jan 2015
I too am new to 3D printing and I just finished my own TwoUp printer. I hooked it all up and got a green light on the power supply box and a red one on my red printr board. I plugged it into my computer and although it did not install correct at first, I downloaded a serial install and got it to work after that. However, I can not get it to connect to RepetierHost. I set up the printer settings but when I go to hit connect I get a pop up saying "The connection failed with the following error: A device attached to the system is not functioning. Make sure your printer is connected, enabled, and connection data is set correct." I don't know what I'm doing wrong or where the problem is (did I mess up when installing the driver? Or does the problem go all the way back to the printr board? Is it just a RepetierHost problem?), but any help would be greatly appreciated. Thank you very much!
01-06-2015, 03:51 PM #3
- Jan 2015
Terrance it sounds like you have the same problem I had at first. Watch this video here https://www.youtube.com/watch?v=cR4-R_8tZhk and download the serial install file that is linked in the description. Follow what he says and it should work for you after that...
