  1. #1
    Jun 2017
    Location
    Washington State, USA
    Now that we can remove the obvious, it could be determined that one or two other solutions could be tried.
    1: you could be experiencing over extrusion you could reduce the flow rate and see if this eliminates bumps.
    2: you could have moisture in filament, placing a dollar store Charcoal Moisture Eliminator in your filament storage container could help.
    Drying filament could be needed the best way to eliminate moisture is by using a food dehydrator
