01-01-2022, 12:15 PM #1
- Jan 2022
Creator Pro/Micro Swiss Extruder & All Metal Hotend - Issues
Recently I upgraded my extruder setup on my Flash Forge Creator Pro 2016. I went with one of the Micro Swiss dual extruder setups. As well as one of their all Metal Hotends (Heatbreak/Throat and nozzles). Upon installing them I've had severe issues leveling my bed, cuz the nozzles sit too low now. If I push the heatbreak further up into the cold block, well then I cant mount the extruder motors themselves anymore cuz it pushes them up out of the way of the mounting holes. I included a pic to help illustrate said dilemma.
If I adjust the throats so I that I am able to mount the motors and get everything back together, then the nozzles basically sit right on the damn plate no matter how I adjust the plate springs. So basically I don't know what I should do. Admit defeat and put everything back to stock, or hopefully find an answer on here that will save me *fingers crossed*
03-22-2023, 02:57 PM #2
I am dealing with the exact same problem as well as trying to understand how to "level" the nozzles so either one will print right.
03-23-2023, 04:43 AM #3
- Nov 2022
- 18
you can use a spacer like this:https://www.thingiverse.com/thing:1886458 it will offset the thickness by triggering the Z axis limit switch early. The models include 2 to 6 mm spacers, or you can resize the Z axis thickness to any size you want.Hope it helps.
