10-16-2020, 07:46 AM #1
- Oct 2020
Print quality, what am I doing wrong
Hello,
I was wondering if someone could assist.
I have an Ender 3v2 and today have done my first print from the stl file and used a new filament from Print-me.
I sliced the print using Cura (i used the same profile as Ender 3 pro), set the bed temp to 60 degrees, nozzle to 200, converted all to gcode and started printing. This is what started coming out:
Can you advise why it is so uneven and it is not printing all the way to the holes, but leaves a gap?
Thanks in advance
10-16-2020, 08:58 AM #2
Is it just 1 layer?
If yes,then you need to increase a bit the distance of the nozzle with the bed.
Also experiment a bit with the temps of the filament.
There is a setting about how much the infill overlays the outer layers.Check that to see if you can close the gaps.
10-16-2020, 09:51 AM #3
for a first print it looks pretty good :-)
Most of my first prints looked like balls of spaghetti :-)
there doesn't look like anything there that messing about with slicer settings won't fix.
Also stock cura is horrible - go download the prusa slicer, easier to use and easier to change options. And no doubt lots of ender proifiles around for it
Now i know that reading manuals is not the current 'done thing'. But the more you learn about how 3d printers work - the easier they are to use.
If you're one of the modern generation who can't read well - there are no doubt lots of how to use prusaslicer' videos on youtube.
Me I'd rather read a manual than watch a video.
But each to their own :-)
Either way, the more you learn the more you'll understand what causes a particular problem and how to fix it.
But gotta say that's a pretty decent looking print.
And don't expect 3d printed parts to look like injection moulded parts - they aren't and they won't :-)
https://www.prusa3d.com/prusaslicer/
10-17-2020, 11:32 AM #4
Just needs a little tweaking. I agree that you might want to try Prusa Slicer. I would start with a hotter first layter height and a little higher nozzle? Keep tweaking, you are close! Good luck and keep at it.
