Results 1 to 10 of 13
08-01-2019, 06:11 PM #1
- Aug 2019
Advice on buying a new 3d printer
Hi all
Still fairly new to 3d printing but getting there.
I started with a Prusa i3 kit which was a great learning curve
I then bought a da vinci unit before going for an enclosed pro unit which was a great little printer out of the box. Never had any issues with it and prints were excellent
I want to buy a new and better printer as I printed a piece which has very small details in the surface but it couldn't print them well
The original designer printed it with a ultimaker 2 but unfortunately I cannot to buy one as much as I am tempted.
Can anyone suggest a printer like this or one that prints small details well but not going to break the bank massively
Thanks so much for your help
08-05-2019, 06:10 AM #2
you already have aprinter that prints small detials - 2 in fact.
All you need to do is change the nozzle size :-)
A 0.2mm nozzle has 4x the resolution of a 0.4mm nozzle.
Change nozzles, Adjust accordingly in your slicer and you've got almost resin grade print detail :-)
picture illustrates size difference beyween 0.4 mm - the big cylinder and 0.2mm, the small cylinder
It's all down to flow rate and viscosity. So for smaller nozzles you need to print slower and hotter, with smaller nozzles you get a lot more back pressure, so don't need to push quite as fast.
But you'll be surprised just how much difference using a smaller nozzle diameter can make.Last edited by curious aardvark; 08-05-2019 at 06:16 AM.
08-05-2019, 08:58 AM #3
- Aug 2019
Ok thanks for that. I've looked online but I'm not sure what size thread the nozzles are
08-12-2019, 05:54 AM #4
all pretty standard. Your i3 will definitely be standard thread.
it's a few bucks/quid - buy some and see if they fit :-)
https://www.amazon.co.uk/SIQUK-Print...gateway&sr=8-5
08-12-2019, 09:56 AM #5
- Aug 2019
I don't have an i3 anymore, but it looks like you cannot change the nozzle size on da vinci jr you have to buy the entire extruder assembly
08-12-2019, 10:05 AM #6
in that case - either get a cheap resin printer if it#sa fairly small part. or get a cheapo kit and use a small nozzle.
08-12-2019, 02:05 PM #7
- Aug 2019
I've thought about getting a resin printer but no nothing about them. Can you recommend a good one that doesn't break the bank
08-21-2019, 07:41 PM #8
- Aug 2015
- 256
Anycubic photon, $300, is pretty popular.... all the inexpensive resin printers are the same in operation, but it's best to get one that has a following so replacement parts remain available.
FDM printers are all limted in detail, you'll be amazed at the detail you'll get out of a resin printer. Build size is the only limitation, it's very small.
08-13-2019, 05:09 AM #9
watch the reviuew thread I posted, https://3dprintboard.com/showthread....ut-getting-one
there seem to be a few around now that are almost identical to the one in the review.
around the $2-300 mark.
The resin is still pretty expensive, and the post processing and apprently, the smell, is an issue.
But you can't argue with the eventual results. :-)
09-02-2019, 07:19 AM #10
- Sep 2019
So to not start another thread I will just post it here.
I would like to know what is the difference between a 300$ 3d printer on ebay and this one Felix 3.1 http://www.secondoption.si/izdelek/f...ik-opa92fel001
I mean the difference in price is huge. Is there any reason for that? Are the materials used to build this printer so much better or what?
Thank you for your insight
