  1. #1
    extremely intuitive cad program
    Good morning,
    What I need is a 3d design software, which does not require installation (only for the browser), and that it is as intuitive as designing in lego or minecraft, that is, by simply placing cubes or similar pieces.
    I have been doing research and I have not found any browser software that meets a minimum of what I'm looking for, and I would like to know if it exists! Obviously the creations should then be convertible to STL.
    Thanks!
    Albert, from Barcelona
  2. #2
    Let me know if you find it.. I use Onshape and the other popular free license product that is cloud based is fusion 360. Unfortunately they are full fledged CAD programs that are not simple to use..
    Good luck
  3. #3
    Staff Engineer
    Jun 2014
    Tinkercad is about the closest program you'll find for performing the tasks you have described. It uses primitives such as "box," "sphere," "cone," etc. to create shapes. Placement is simple dragging, resizing equally simple. Some alignment options are available. As requested, it is web based, and allows STL export. Free for all to use.
  4. #4
    Thank you for your answers.
    I've used Tinkercad but what i'm looking for i something much simpler (someone who has never done any design can do something simple). For example, there is a web called "publish your designs" (i can't post links) which is good for design but can't convert it to STL
  5. #5
    Staff Engineer
    Jun 2014
    If Tinkercad is too complex for a beginner to understand, I'm afraid that I don't have an answer. I've guided five year olds to use the program with minimal difficulty. Good luck.
  6. #6
    This is helpful. I'd like to try it
  7. #7
    Jun 2017
    Location
    Washington State, USA
    Quote Originally Posted by fred_dot_u View Post
    Quote Originally Posted by apares8 View Post
    As far as I know TinkerCad is the simplest, there is many tutorials on Youtube! I find the quickest way to learn is by watching these YouTube videos.
    https://www.youtube.com/results?sear...rcad+tutorials
