Thread: Slic3r 1.1.4 is out
06-07-2014, 06:11 AM #1
- May 2014
- 17
Slic3r 1.1.4 is out
Slic3r 1.1.4 experimental is out!
Anyone try it yet?
Improvements:- Holes in object footprint are now ignored when generating raft to make it more continuous
Changes:- Retract on layer change is automatically disabled with Spiral vase is enabled
- The command line --save option will not only save the options that were explicitely specified on command line, without the implicit defaults
Bug fixes:- Fixed a bug in an upstream library causing crashes or missing perimeter segments in rare situations (#2028)
- Fixed a crash when skirt was contained in brim area (#2058)
- Fixed a regress causing bridge flow to be incorrect when a default extrusion width was specified (#2027)
- M73 was exceeding 100% when multiple objects were printed together (only for Makerware/Sailfish) (#1912)
06-10-2014, 06:02 AM #2
Has anyone installed this yet? I'm always hesitant to try out the experimental versions.
06-10-2014, 09:14 AM #3
