Results 1 to 10 of 11
05-27-2014, 02:53 PM #1
- May 2014
- 9
05-27-2014, 04:23 PM #2
- Honolulu, HI
- 199
Very nice! Looks super stable!
05-27-2014, 04:55 PM #3
- Apr 2014
- Netherlands
- 76
Nice, all aluminium! But we want specs, what can this sturdy beast do? ;o)
05-28-2014, 08:11 AM #4
- May 2014
- 9
It runs very well it is very rigid and very reliable the extruder is something I came up with which works flawlessly it uses a serrated drive wheel off mig welder it is over 1 inch in diameter so more teeth are engaged in filament at a time and has 100 to 1 gearbox here is a crappy little video throwing its weight around click on picture should be a link the XY and Z are nema 23 motors
05-28-2014, 08:34 AM #5
- Dec 2013
- Georgia
- 934
Wow, that thing is a beast. I don't doubt that it's solid, the company worked for used to build testing rigs with that same aluminum extrusion.
I suppose it's running RepRap software?
How much did you spend on this machine?
05-28-2014, 12:36 PM #6
- Apr 2014
- Netherlands
- 76
Nice, but I was more interested in speeds to be honest. My thought was that it should be able to run at higher speeds because it looks so sturdy.
I see you use Repetier as firmware right?
05-28-2014, 07:24 PM #7
- May 2014
- 9
It can print at much higher speeds and with no machine deflections problem being I'm a little bit of a stickler for quality and it's the actual filament being laid down on top of the layer before it that governs the quality. Like I say I'm a little fuzzy it definitely will print and 100 mm a second my acceleration is set for 2000 on the X and Y and I definitely could go up on the acceleration. If I remember right the little bottle opener took 32 minutes. Plus that is ABS not PLA which would be faster
05-28-2014, 07:30 PM #8
- May 2014
- 9
I had most of the stuff laying around the aluminum extrusions aluminum plate linear rails and bearings three of the four motors basically I had bought that stuff a long time ago and was very cheap so all I had to buy for the build was one motor the electronics in a couple of belts and the hot end
05-28-2014, 11:33 PM #9
that looks really solid! love to see some videos of it in action
05-29-2014, 10:26 AM #10
- May 2014
- 9
