Results 1 to 10 of 255
11-04-2014, 08:09 AM #1
So I didn't buy enough wire to power everything up, but I had enough for the 11v and the 5v, and will need to get more for the heatbed. I hooked up my laptop and fired up pronterface and it seems like everything is working except the z access. Facing the printer the left side moves, but the right doesn't want to do anything. it looks to be trying but I am thinking something is binding so will look at that tonight.
In Pronterface if I click on the right side of the X axis, it should go right correct? If so I have the plug reversed.
The other question I have is that I noticed that I mounted the fan for the hexagon, so that it is pulling air, rather than pushing. Will that be ok, or do I need to flip it?
So encouraged to actually get this far!!!!! My time has been really limited to work on this so happy to finally get some movement!
11-04-2014, 08:55 AM #2
Mine has also done this for the entire time I've owned the printer and I have always had to press the opposite button to get it to go the right way. The important thing is to make sure that the X axis moves from right to left (towards the x endstop) when you press the home button in pronterface.
I'm guessing there might be a way to flip the X axis button direction in the pronterface options but I haven't tried this personally.
Mine pushes air but I believe I have heard other folks on here say they flipped theirs and had it working.
