Results 1 to 10 of 18
Thread: SSR keeps melting.
12-26-2018, 11:04 AM #1
Ah, OK. The SSR will have two switched contacts and two control pins. The MakerFarm relay board as two terminals that are switched through the relay, the two small wires that are the control pins, and two additional terminals that are just shorted together. To move from a MakerFarm relay board to a SSR, one wire from your power supply to the bed would pass through the SSR, and the other wire from the power supply would go directly to the bed, without passing through the SSR. Edit: and RAMPS D8 would connect to the control pins on the SSR (watch the polarity).
I assume only one of the two terminal blocks was damaged on your relay board. If so, which one and how bad is the circuit board? If the board isn't in bad shape and the damaged terminal block does not have traces going to the relay, just splice those two wires together. If the damage is at the terminal block with traces going to the relay, you could consider unsoldering both terminal blocks and reinstalling the good one at the location with traces going to the relay. Then the other two wires would be just spliced together.
12-26-2018, 11:35 AM #2
- Aug 2016
- 25
Two of the connectors were melted, I removed both and direct soldered everything back in place, but during reinstall I cracked one of the solders joints due to it being brittle, and me being crappy at soldering.
So I am ordering an SSR, heatsink, and silicone covered 12 awg wire and starting over.
Thanks for the tips, I will post a mock up when I get it.
