Results 1 to 10 of 11
Thread: BlTouch on Hictop Prusa i3
04-20-2018, 07:20 PM #1
- Apr 2018
- 6
Hello,
I've installed the sensor and updated the firmware to marlin 1.1.8. However, when i try the auto bed level, it crashes on the bed.
Also, when i manually move my Z axis 1mm, it moves a lot more (+- 8mm).
The white and black are plugged in to the Z- socket and the other 3 on the D11 pins.
I've asked hictop to send me the original firmware but, haven't heard anything from them.
Board is MPX.3
I can't attach a zip of my firmware configs. Ask for parts of it and i'll provide it.
Any help would be greatly appreciated
04-21-2018, 09:24 AM #2
Hello;
Hictop software can be downloaded from the Hictop's web Page. Under the Tab "Download" drop down box "Firmware, Software" Then select the printer you have for the download.
https://hic-3d-printer.myshopify.com/
I have setup all versions of Marlin 1.1.X for 3DP11 and 3DP12 Aluminum Frame though do not have a BL-Touch I use a TL-W3MC2
If you need help with Marlin I could assist.
04-21-2018, 10:27 AM #3
- Apr 2018
- 6
Thanks for the info, i've replaced the firmware with the one from the one i downloaded from the hictop site and was able to fix the Z motion so it now moves correctly.
I can't seem to be able to upload a zip from my marlin 1.1.8 firmware folder but, i've put my configuration.h file into a txt that i'm attaching here.
If you have any pointers, it would be greatly appreciated.
Thanks
04-21-2018, 12:40 PM #4
I do not see a Marlin 1.1.8 Configuration.h file attached file is for a much older version.
Try This " https://drive.google.com/open?id=1Gh...ibTgbl5ZUd1XAw "
Compiles With Arduino 1.8.4Last edited by Roberts_Clif; 04-21-2018 at 01:03 PM.
04-21-2018, 01:57 PM #5
- Apr 2018
- 6
Thanks a lot buddy, Z- i now working fine.
Now i just have to figure out my offset, approx 2-3 mm from the bed.
Have a great weekend
04-22-2018, 10:56 PM #6
