Results 1 to 10 of 31
Thread: Kossel Mini Build (750/360)
06-28-2014, 05:36 PM #1
I think there is a setting in Repetier to not allow the extruder to turn until it is 170 degrees. I use by LCD panel to turn the extruder motor on my Kossel Mini.
06-30-2014, 02:26 PM #2
- May 2014
- 100
Yeah I was able to get it to work by turning the minimum extrusion temp as well as the minimal defect temp below -10 degrees. I didn't have my hot end thermistor plugged in so the defect temp showed -58C. Now I am trying to wire up 615rakabMOL._SL1500_.jpg to my dedicated power supply. Any ideas?
Mechanically its up and running, but the belts aren't too tight.
