  1. #1
    3D Printer Filament Types :ABS
    Acrylonitrile butadiene styrene [abs] 3D Printer Filaments ranks as the second most popular 3D printer filament, after PLA. But that just means its the second most commonly used. With respect to its material properties, ABS is actually moderately superior to PLA, despite being slightly more difficult to print with. Its for this reason that ABS is found in many manufactured household and consumer goods, including LEGO bricks and bicycle helmets!
    Products made of ABS boast high durability and a capacity to withstand high temperatures, but 3D printer enthusiasts should be mindful of the filaments high printing temperature, tendency to warp during cooling, and intense fumes. Be sure to print with a heating bed, and in a well-ventilated space.
    Read our in-depth article on this 3D printer filament
    3D Printer Filament Properties: ABS
    • Strength: High | Flexibility: Medium | Durability: High
    • Difficulty to use: Medium
    • Print temperature: 210C 250C
    • Print bed temperature: 80C 110C
    • Shrinkage/warping: Considerable
    • Soluble: In esters, ketones, and acetone
    • Food safety: Not food safe
    When should I use ABS 3D printer filament?
    ABS is tough able to withstand high stress and temperature. Its also moderately flexible. Together these properties make ABS a good general-purpose 3D printer filament, but where it really shines is with items that are frequently handled, dropped, or heated. Examples include phone cases, high-wear toys, tool handles, automotive trim components, and electrical enclosures.
    For more Head over to All About Buying 3D Printer Filaments
  2. #2
    Engineer ralphzoontjens's Avatar
    Nov 2013
    Location
    Tilburg, the Netherlands
    Follow ralphzoontjens On Twitter Add ralphzoontjens on Facebook Add ralphzoontjens on Shapeways Add ralphzoontjens on Thingiverse
    We have to stress that people have to be aware that when printing ABS, the fumes are significantly toxic so you need a well-ventilated area.
    Even when printing PLA above 200C VOC's are released - though much less than with ABS - including ammonia, cyanidric acid, phenol and benzene.
