Results 11 to 20 of 22
06-13-2017, 01:07 PM #11
so now all you need is to incorporate it in a nice shiny cabinet and get some crowd funding cash :-)
08-06-2017, 01:08 AM #12
- Dec 2016
- 13
Been doing some more work on this project.
I am at v3 of the machine.
Switched to using a raspberry pi 0 w as the controller is stead of a netbook. The pi has a real serial interface and the chip doing the usb to serial did not really like emi in terferance with the new linear actuator I was using.
08-06-2017, 07:46 AM #13
Hello,
Like your 3D Printing system ingenious.
Like you I too had EFI problems, It started when I purchased a 2nd 3D Printer that was 24volt Hictop 3DP12.
I solved you EFI troubled by 3D Printing a case and lining it with Aluminum Duct tape and Grounding the Duct tape.
This was a simple fix you may think about as a solution for your EFI troubles, I will supply a link to the My Complete Post.
http://3dprintboard.com/showthread.p...2-EFI-Problems
Would really like to hear more about this 3D Printer you built.
I too print on a disposable print surface, though my surface is a Vinyl transfer Paper Tape used for transferring Cut Vinyl from its origin surface.
Vinyl transfer Paper Tape cost about 10cents per 1 Foot bed covering, is quit a bit more than your single sheet printer paper, though is still disposable and has a adhesive back.
08-06-2017, 12:23 PM #14
- Dec 2016
- 13
I am interested in having some one replicate the printer.
I have been working through getting the documentation together.
If you are interested PM me and we can chat on google hang outs.
08-07-2017, 05:42 AM #15
you mention a r-pi as controller. But still has netbook in the video.
presumably you could mount the pi somewhere on the printer frame.
How easily do the prints detach from the paper ?
08-08-2017, 02:36 PM #16
I printed a model on a sheet of paper, if you roll the paper under the print model paper comes right off.
On larger prints, I could not keep the single sheet paper flat enough clipped or taped to keep print from warping, even resorted to a 90lb card stock paper.
Could you direct me to a video showing your printer printing a larger 3D Model.Last edited by Roberts_Clif; 08-08-2017 at 03:11 PM.
09-22-2017, 09:36 PM #17
- Dec 2016
- 13
So I am at maker fair new York this week end showing off the printer. Stop by the autodrop3d booth if you are interested.
09-25-2017, 10:51 PM #18
- Dec 2016
- 13
So got some good news.
Been working on this project a lot.
finally got this going.
https://www.kickstarter.com/projects...us-3d-printing
10-02-2017, 12:06 AM #19
- Dec 2016
- 13
10-02-2017, 06:52 AM #20
Any videos of larger prints ?
Like the new bed and removal system, though it does lose printed information attached to the print, which was also quite neat :-)
Good luck with the kickstarter :-)
for anyone out there - the $599 for printer and autodrop kit is a bloody good deal, still 10 left !Last edited by curious aardvark; 10-02-2017 at 07:00 AM.
