Results 1 to 10 of 474
09-21-2017, 03:55 PM #11
- Jul 2017
- 193
Thanks CA and number40Fan, I just measured and they are all the same.
It sounded wonky, that's why I ran it by here.
Hope to finish build this evening. I adjusted the belts using the method in the He3d K200 D8 tutorial 8 at the 2 minute mark where you make the belts tight as you can then move the top frame member up using the adjustment screws at the top.
