Results 1 to 10 of 474
07-14-2017, 03:21 PM #11
where'd you get the bearings ?
And have you got pictures :-)
So I'm thinking what is the actual physical speed limit of the printer ?
If she can do 150mm/s at 0.3mm - she should be able to do 200mm/s at 0.2mm layer height. Same volume of plastic right.
Or will that make her explode !
How fast can the stepper motors turn ?
I think it's something to do with inverting the y axis.
It used to be fine, just printed what showed in the preview. then when I installed version3 it started showing text reversed in the preview but printing it fine.
But with the delta it doesn't seem to matter what shows in the preview it always prints it reversed. Which is bloody weird.
Sod it going to give it a go :-) Also test if text is right way round yet.
right here goes super speed !
well that works, still got text issues. doing it again with no inverted y. test looks mirrored on preview, so might print right way round.
The fine detail isn't brilliant - but i reckon it would be good enough for that marble run - if I can ever slice it lolLast edited by curious aardvark; 07-14-2017 at 03:57 PM.
