Results 1 to 10 of 10
05-08-2017, 01:36 PM #2
you should be able to import the ipt file into your copy of inventor and then EXPORT it as an .stl file.
Export operations in programs are usually in the same menu as save and open.
try this: https://forums.autodesk.com/t5/inven...e/td-p/4767833
and good luck :-)
