Results 1 to 8 of 8
01-30-2017, 10:12 AM #7
- Nov 2016
- Lancashire, UK
- 36
Hi rudschul,
I have some sympathy with you. I have an open ticket that has not yet been resolved. It is to do with accuracy and the printing area. I printed two, identical parts yet one comes out a full 1mm smaller than the other. Both parts should be 39mm diameter. I am also having some issues with the X and Y axis dimension stability. It looks like the further from the centre I print, the smaller the parts are. Do you have the same problem?
I now am able to print over a much larger area than before as I was finally able to adjust the front lamp shroud properly. I did it by disconnecting the left and right lamps so I could easily see the shadow. However, I have to raise the powder temperature to 174.8C and lower the print speed to 550 mm/s. Even at these settings I cannot print within 30mm of the left side. At this distance the laser seems very dim and does not sinter the powder sufficiently.
I do not understand why you don't have access to the 'ticket' system any more. Have you tried emailing Dominik, one of the founder members? His email is dominik.solenicki@sintratec.com I get frustrated with the 'ticket' system because you don't always get a quick answer and it can be days before you get a reply.
What error codes are you seeing? I always get two error messages when I close the program after loading a print file. I don't get any others at the moment. I opened a 'ticket' on this back in November but not had a reply yet and the ticket was closed.
