Results 21 to 25 of 25
Thread: Noob questions, The Machine
12-01-2016, 02:53 PM #21
- Nov 2016
- Earth
- 28
So I'm learning. From what I've read, if I want stronger parts with better inter layer adhesion, I want to go to a larger nozzle. The supposed advantages are that the previously laid down layer retains more head, it will bond better as the new layer is laid down. It also speeds printing considerably. For aquarium parts I think I should actually consider the E3D volcano. As a start, I will get the largest nozzle my head supports.
For water tightness, is that all down to inter layer bonding?
Anything that isn't watertight can be painted with varnish, or any of the propriatary 3d print smoothing compounds around.
pet-g has much better layer bonding than abs, prints on an unenclosed machine and isn't much more expensive than abs. It also has a lot less shrinkage, which helps reduce micro gaps in the structure.
Bonding would be the one issue. The only product available to bond to other plastics like PVC or acrylic it Weldon 40, a rather expensive two part bonding agent. If it works and this is the only down side, I can live with that.
The fumes from abs are not as much of the problem as it's shrinkage and all the acetone you end up breathing in.
Yes people use it, I suspect many of them do so beacuse they haven't bothered to look seriously at the alternatives. The materials advances in 3d printing filaments in the last few years is just astonishing.
Another material you might want to look at is ninjatek's Armadillo. It's a rigid supertough material, that apparently prints easily. Handling it you'd think you were holding some kind of hardened nylon. I believe they said it was polyurethane.
Pretty impressive stuff.
I haven't tried it yet - but had along talk to the ninjatek guys and handled a few prints. The only thing that impressed me more this year materials wise, was a fibreglass composite from an italian company (maybe spanish). That was as light and strong as traditional fibreglass and printed - again - on an unenclosed machine.
Then you have innofil's new Pro 1 - easily the best material I've printed with for ease of use.
Lots of different applications depending on how hot and how fast you print it. Also food contact safe.
Edit: Regardless of the material I work with, I plan to enclose the machine. I've spent enough time around injection mold machines (very large ones) to understand how finicky plastic can be. Since I'm concerned with long term structural integrity, I want to manage the print environment as much as possible.
12-01-2016, 05:38 PM #22
- Apr 2015
- Northern Ohio
- 198
It really depends on what your accuracy requirements are. A larger nozzle will print faster but I am not sure it has the advantages that you are citing. A normal .4mm nozzle can be setup to produce those exact same results. Extrusion width, your multiplier, and extrusion temps are you friends. These parameters are in your slicer.
Water tightness is going to rely pretty heavy on your shell/perimeter settings. Lots of perimeter/top/bottom layers. You and I both know that coating anything in a saltwater environment is something to proceed with extreme caution.
You don't breath in acetone during printing. It's a solvent that dissolves ABS. You use acetone as a method of smoothing, creating slurry, or cleaning the bed with Kapton tape. What you are smelling during printing is the styrene. ABS = Acrylonitrile Butadiene Styrene. Does it smell? The short answer is yes. The real answer is that when processed at the correct temps the toxicity of the fumes is minimal. ABS when burned as in a fire condition is very toxic which is why they have flame retardant grades for certain applications (molding option) but that is not what we are doing. Extrusion temps are below injection temps. If it were toxic when processing OSHA would be all over the injection molding industry as it and nylon are the most processed plastics on a large scale and they don't require breathing aspirators for the workers. Can it irritate some peoples noses? Certainly.
Like i stated before the application defines the application. Material selection is based application. The array of thermoplastics is pretty wide ranging and application specific. Check out the range of what is out there on matweb http://www.matweb.com/search/MaterialGroupSearch.aspx Each of these has a use as matweb just covers the most common for each category not the full range from Dow, Bayer, GE, etc.... Yes the printing industry has brought out a lot of filaments but they are based on existing polymers with a modifications to make them easier to print. I use a lot of the stuff that is out there. There are applications for all of it.
Controlling the environment as much as you can is a very wise approach.
12-07-2016, 10:43 AM #23
if you enclose it leave a door.
the trick to pla is cooling fast, so that;s one material that you don't want to print in an enclosed setup.
back to the cold smoking - thing - that I know a LOT about.
what sort of setup are you talking about ?
12-07-2016, 12:16 PM #24
- Nov 2016
- Earth
- 28
Well how exactly am I gonna get in there without a door? Like I'd ever do something that silly...
OK, I get your point. I need a way to print cold as well. I plan to make a stand out of 8020 quickframe. I'll work out a way to make the panels easily removable for access around the printer. I've learned the hard way that you should always make your equipment as accessible as possible.
I could probably MacGyver something from existing materials, but a 3d printed manfold would be much more elegant.
12-14-2016, 05:40 PM #25
- Nov 2016
- Earth
- 28
OK, Printer ordered. Again. Hopefully the transaction goes through without all the drama this time...
From all the reading I've been doing, all the low cost large bed printer kits out there have issues with powering the heat bed. Either the bed is greatly under powered and has trouble getting up to temp in a reasonable amount of time, or you get a great heat up time, but the main board and/or PSU can't handle the power draw.
The Tevo's 370 x 250 mm bed heater draws 400 - 500 watts of power. The silicone heat beds of similar size start at 400w and go up from there.
Other builds have a smaller PSU and ~150w heatbed that will not get to the 100C+ needed for some materials.
I'm only guessing, but I suspect it is the $499 price point companies are trying to hit that has got them where they are now.
I don't understand the main board chain of supply, but I would imagine that there is a market for a board properly designed to handle 500-600w at 24v.
I'm going to try controlling the heat bed separately using 24v out from the PSU though an SSR or mechanical relay. I may actually just shell out the money for a real Omron SSR and be done with it. If the PSU lets out its magic smoke I can upgrade to a proper Meanwell 600w PSU.
The internets claim I don't need to spend this much money for a relay, but I don't know that any of this 'Internets' has the appropriate training to make this call.
Now, lets see if the shippers can beat Santa.
