Results 1 to 10 of 13
09-26-2016, 08:34 AM #1
- May 2015
- 107
FFCP 2016 Ninja Flex feeding issues. I need advice please.
I am having issues getting ninja flex to feed. Semi-Flex is a little better but not much. When I load the filament it seems (at least to me) that it extrudes slower than than ABS or PLA does. I took a video of it so you can see if I am nuts or not. The hotend temp is set to 230. I tried this thingiverse mod but it did not work for me. http://www.thingiverse.com/thing:857200
My question is: what can I do to get this to print flexible filaments reliably ? What do you do to run flexible filaments? I bought this printer because it advertised that it can run flexible filaments. I contacted Mr. Tang but he said he does not use flexible filaments.
https://youtu.be/ie5DEcihR9k
https://youtu.be/hPTtZ8q1BcE
09-26-2016, 09:41 AM #2
okay you've got two options.
Modify your extruder or switch to polyflex.
The only colour of ninjaflex that will reliably print on an unmodified mk8 extruder is green. Nothing else I've tried will work.
Polyflex is the best flexible filament for printability.
The best rubber filament I've used is flexismart.
For any flexible filament you need to reduce the print speed to a MAXIMUM of 30mm/s (ignore what it says on the packet if it says you can print up to 50mm/s) And run it at the top end of the recommended print temperature. Loading can be an issue as it loads much faster than it will print at.
The trick is to stop the load as soon as you see the filament come through the nozzle.
Sometimes I find I have to unload and reload a couple of times to get it setup properly.
Polyflex, just works. But is a flexible plastic (pla) NOT a rubber based filament
The most reliable tpu (rubber based) flexible filament I've used is flexismart. Runs at 210 and 30mm/s without any problems.
I'm just about to order some more, which will be the first time I've found a rubber filament reliable enough to actually use a whole roll up !
It's not quite a s strong as ninjaflex - but it's a helluva lot more user friendly.
Sebastien has used a fariyl simple modification on his printer and reckons it prints ninjaflex really well now.
Used one of the little plastic ptfe tubes that sits inside the heater block. You insert it between the top feed hole oin the extruder and the feed hole for the heater. carefully cut out the section by the feeder/hobbed bolt so the teeh can still engage the filament and the tube doesn't get caught by the teeth.
Essentially it stops the filament from flexing and getting wrapped round the hobbed bolt and redirects it straight to the heater block.
Simple and ingenious :-)
09-26-2016, 11:28 AM #3
09-26-2016, 11:31 AM #4
Another thing (CA already knows this but I'll say it for the benefit of those that don't):
We often speak here about rubber filaments. This however is incorrect as rubber is not a thermoplast and cannot be printed. So when we say rubber we really mean rubber-like. Generally tpe/tpu.
'Cos someone's gotta cross the t's and dot the i's...
09-26-2016, 03:25 PM #5
that's one of the things I really like about flexismart. It actually behaves and feels like proper rubber.
Industrial rubber and the sap from the rubber tree - totally different things :-)
[QUOTETakes all of 2 minutes to drill ][/QUOTE]
what did you drill ?Last edited by curious aardvark; 09-26-2016 at 04:06 PM.
09-27-2016, 03:27 PM #6
- May 2015
- 107
Where do you get flexismart at?
09-27-2016, 03:31 PM #7
- May 2015
- 107
Do you have a link to this Sebastien and his tube?
09-27-2016, 03:35 PM #8
flexismart I get from amazon.co.uk
As for sebastien LOOK UP ^^^^^^^ 4 posts
09-27-2016, 03:42 PM #9
- May 2015
- 107
I am in the US No Amazon link to buy in US.
09-27-2016, 03:51 PM #10
- May 2015
- 107
I looked up 4 posts but I must me going blind. I see no procedure or "how to " for inserting a plastic tube in my stock extruder.
