Results 11 to 19 of 19
Thread: Hinged Ganry with ABL probe
09-14-2016, 08:14 PM #11
- Dec 2014
- Canada
- 498
Here are the results of the M48 V4 P10
READ: Mean: 0.664402
READ: Standard Deviation: 0.002912
09-14-2016, 08:17 PM #12
- Dec 2014
- Canada
- 498
so whats considered a good result?
09-15-2016, 06:44 AM #13
- Jul 2016
- Pennsylvania, USA
- 255
Hi
If you are trying to print a layer height of 0.2 mm, a bed that is good to 0.02 is "ok". Anything at 0.002 on a 0.2 mm layer is well beyond what you can see. As you scale layer height, the limit (obviously) changes. It is not at all unusual to look at a "three sigma" (three times the standard deviation) to estimate how good the result will be most of the time. If you have a very un-level bed, and are taking a lot of points, that figures into the estimation as well. On a dead flat aluminum bed, I may only need three points. On a monster I may take a 5 x 5 array. With three points, the flat plate may well be better overall than the crummy bed, even after 25 point correction.
Bob
09-15-2016, 07:55 AM #14
- Dec 2014
- Canada
- 498
Are you referring to the Mean or Standard Deviation?
09-15-2016, 09:26 AM #15
.003mm of standard deviation is good. Especially if that was accomplished with 10 probes. I've been able to get numbers down at .001mm but I have my probe leg designed to not move at all. Considering you are moving a lot of stuff to get the switch to trigger, .003mm is perfectly respectable.
09-15-2016, 11:36 AM #16
- Jul 2016
- Pennsylvania, USA
- 255
09-18-2016, 08:34 AM #17
- Dec 2014
- Canada
- 498
Just updated to Marlin UBL v2 redid the probe test
nice results! from M48 V4 P10
READ: Mean: -0.997358
READ: Standard Deviation: 0.000677
09-18-2016, 10:01 AM #18
- Jul 2016
- Pennsylvania, USA
- 255
Hi
It looks like your data is pretty good.
You might want to see if this can be moved to a more suitable sub-forum. This is the MakerFarm section and they don't have any CoreXY stuff.
Bob
09-18-2016, 11:00 AM #19
- Dec 2014
- Canada
- 498
sure, but this isnt corexy related really.. I am planning on making a version of this hinged gantry for my Makerfarm i3v 12
