Page 1 of 2 12 LastLast
Results 1 to 10 of 42
  1. #1
    Student
    Aug 2016
    Location
    Raleigh, NC
    Hello,
    I am slowly progressing through my build. I am attaching the y extrusion to the frame and they never seem to get tight. It says to make sure that they are level with the bottom of the bracket, but when I try to tighten, they rotate and move all around and never seem to get tight. Any thoughts?
  2. #2
    Engineer-in-Training
    Jul 2014
    Quote Originally Posted by microjedi View Post
    Hello,
    Check the length of your screw. When I built mine some screw's were to long preventing it from tightening properly.
  3. #3
    Student
    Aug 2016
    Location
    Raleigh, NC
    Quote Originally Posted by BLKKROW View Post
    That may be it. Did you buy new screws, or use washers to fix it?
  4. #4
    Jul 2014
    I had a few extra on hand, but if you don't want to purchase any then just use washers.
  5. #5
    Student
    Aug 2016
    Location
    Raleigh, NC
    I'll have to purchase the washers too. I am a new guy. I haven't built up a big stock of extra parts yet.
  6. #6
    Jul 2016
    Location
    Pennsylvania, USA
    Hello,
    Hi
    If you are using the correct hardware, your extrusions are not tapped deep enough. You can either have Colin swap them out or get a tap and clean up the parts you have. If you have tapped parts before this one is no different. If you have never done it, spend some time with YouTube. There is a bit of a technique to doing it without breaking the tap.
    Bob
  7. #7
    Jul 2016
    Location
    Pennsylvania, USA
    Hi
    Ok, here's a picture
    (image *should* have been here but it isn't ....)
    It's a shot of the foot I decided to use. I fiddled around a lot and ultimately decided on a pretty simple design.
    Let's see if the image goes through or not. The "post image" button didn't seem to do much.... Drag and drop also did not work. Try again with a *really* small file ... finally it works.
    Next up is the "custom" bed mount piece
    That is a bit higher resolution than the first one so this is a bit encouraging. The mount piece lets the heater "float' when there is no glass. Put another way, the clamp holds both the glass and the heater in place. That way as the PCB changes size during warmup, things don't move all over the place.
    Bob
  8. #8
    Staff Engineer printbus's Avatar
    May 2014
    Location
    Highlands Ranch, Colorado USA
    Add printbus on Thingiverse
    Quote Originally Posted by uncle_bob View Post
    The board currently defaults to inserting images as thumbnails, which people can click on to enlarge. I realized the other day that in the post edit window, you can over-ride this by double clicking on the image and selecting full-size in the properties window that pops up. Edit your post again and give that a shot.
    EDIT: And yeah, the board won't accept the high-res pictures people can get from the phone cameras these days. I usually resize photos down to about 800x600 pixels before uploading.
  9. #9
    Jul 2016
    Location
    Pennsylvania, USA
    Quote Originally Posted by printbus View Post
    Hi
    For those who haven't quite yet guessed, printbus was coaching me through the photo process ... THANKS !!!!
    Bob
  10. #10
    Jul 2014
    Hi
    Bob
    I think the nuts are tapped, but I think the screws are bottoming out in the extrusion.
