Results 1 to 10 of 30
07-03-2016, 04:17 PM #1
- Jul 2016
- 14
That is correct as well.
The the pour tube is called a "Sprue". It is both tapered and oversized to help build up as much hydrostatic pressure as possible (also makes it easier to pour into). It also acts as a "Riser" that stays molten long enough to feed the metal as it shrinks as it cools which is called the "Suck".
Let's see; it looks like lead doesn't boil until 3,180F. So you could get it plenty hot enough to work for the process. How much hotter it needs to be over the melting point of 621F would take some experimenting. I imagine if you got it up to around 1000-1200F that seems like is should be adequate.
