Results 1 to 10 of 16
06-04-2016, 11:56 AM #1
What is the TF card? (SD Card?) Does Flashprint store the print on the SD card for USB printing? I've never used printing over USB as it was extremely unreliable for me. I've also read many other people having problems with it at various times, without any 'rhyme or reason'. I suspect you have a problem with the USB communications, either in the printer, computer or USB cable..?
06-04-2016, 12:14 PM #2
- Feb 2015
- Netherlands
- 15
No No,the TF-card is the little micro sd card on the motherboard.When you transfer the G-code via usb it will be stored on this internal flashcard.I know Flashforge has change de VID and PID for usb after a firmware update.So we can not use Simplyfy3D anymore over usb.And what is Flashforge doing to solve this problem?Totally NOTHING.We wait for months now to use Simplyfy3D over usb.I rolled back to a previous firmware to use the software. You can see the threat in the link.
Oke but that is not solve my problem.I am a CNC engineer so I think I have to check the G-code in the file.
https://forum.simplify3d.com/viewtop...hforge+dreamer
06-04-2016, 06:45 PM #3
Ah ok, thanks for the information, and holy cow what a mess.
So I take it that the control set does not copy the .gcode to the TF-Card when printing from the SD card??? If that's the case then I think you are on the right track with your diagnostics, and a closer look at the TF-Card is needed. If the control set does copy the .gcode to the TF-Card when SD-Card printing then I think the problem is unrelated to the TF-Card. I know, I know,... Not giving you any help/information you don't already know..
Please let us know how you make out.
06-05-2016, 05:58 AM #4
- Feb 2015
- Netherlands
- 15
PHP Code:[PHP][PHP][PHP]
Thank you guys to think with me!
