Results 1 to 10 of 10
08-07-2015, 09:15 AM #1
Wanhao Duplicator 5S Mini - 3D Markt
- Best Layer-resolution! 0.02mm per Layer
- Extraordinary Printing Speed- 300mm per second!
- Massive Building Volume- 295*195*205mm!
- Extremely Portable
- 1 Year Full Factory Warranty
Capable of printing up to 12 litres of volume, the Wanhao Duplicator 5S Mini may exceed the customers’ expectations as it is equipped to print larger amounts than what its name may suggest. Because of its small size, the printer is easily transported and makes for a perfect desktop placement. With an exceptional resolution of 0.02mm, the Duplicator 5S Mini provides the user with a more serious detailed 3D Printing experience and the ability to produce a range of promising goods. Functioning at a high performance, the patented extruder avoids any interruption problems that may occur and in turn allows the user to print with ease and efficiency. The Duplicator 5S is fitted with an all steel framework, which gives it a modern sleek finish and promises a long service life. Finally the ability to print big and fast in a limited space has arrived! Don’t miss out!
Advanced features:
• Huge building volume: 295*195*205mm!
• One of the fastest 3-D printers in the world- up to 300mm/sec!!
• Layer thickness: Best resolution in this price class! 0.02 – 0.4 mm
• Fitted with a high performance, patented extruder. No clogging problems
• Print from the built-in memory and avoid interruptions caused by your PC or USB-cable
• All-steel frame work, super long service life
• Industrial-grade motion system, high stability and precision
• Speed: 20 – 300 mm/s
• Positioning precision: 2.5 micron on Z axis, 11 micron on XY axis.
• Overall dimensions: 460 x 530 x 480 mm
• Shipping weight: 25 kg
• Linear ball bearings
• 4x20 LCD character display and turning and press control pad
Specifications
Printing technology FFF Fused Filament Fabrication
Extruders 1 Single Extruder
Interface Print with SD Card or direct via USB Port
Build volume 295 x 195 x 205 mm, about 12 l
Layer resolution 0.02mm - 0.4mm
Print speed 20-300 mm/s
Position precision X,Y Axis 0.01mm
LCD Display 4x20 LCD character display and multi-direction control pad
Operating nozzle temperature Recommended Maximum 230 C
Platform temperature NA
Supported materials Prints PLA, PET
Filament diameter 3.0+-0.1mm
Connections USB, SD Card slot
Chassi Extreme XV Rock Steel structure
Mechanical Property
Overall dimensions: 295*195*205mm!
Shipping Weight: 25kg
Precision ground Core XY.
Snap-on, snap-off filament assemblies
Full Extreme steel Structure
SOFTWARE: WanhaoMaker
Compatibility: Linux, OSX, and Windows
Print from SD card or over USB
Input file type: STL, gcode
Materials
Works with PET and PLA.
Filament diameter: 3.0 mm
For more information please e-mail us at info@3dmarkt.at or checkout our website www.3Dmarkt.at
The following product can also be found on ebay http://www.ebay.com/usr/3dmarkt?_trksid=p2047675.l2559
You can also Find us on Facebook https://www.facebook.com/3DMarkt?fref=ts
24367360-origpic-ab335c.jpg_0_0_100_100_300_300_85.jpg24367360-origpic-1db281.png_0_0_100_100_300_170_85.jpg24367360-origpic-0cfc1f.jpg_0_0_100_100_300_300_85.jpg
