Results 1 to 10 of 17
04-29-2018, 08:01 AM #1
I went with a TL-W3M and mounted under the Bearing Mount.
This is a low profile proximity sensor that I have wired to my ramps 1.4 - 5volt power source. This configuration has been working correctly for nearly 2 years without any problems, having the ability to mount the sensor withing 15mm of the nozzle to achieve the most accurate bed leveling. I on the other hand choose to mount the sensor 25mm directly behind the nozzle.
The mount has a adjustable thumb screw to adjust the height easily and quickly with a 3 Position bottom mount screw holes Left, center and Right.
https://media.digikey.com/pdf/Data%2...x%20Sensor.pdf
