Thread: Bypassing the built in relay.
04-11-2016, 08:47 PM #1
- Jul 2014
- 305
The Pegasus kit now comes with the heat relay built into the heated bed. However, I would rather us a solid state relay and wanted to know if anyone has bypassed the built in relay.
04-11-2016, 08:51 PM #2
Yes, the switch contacts on the built-in relay have been jumpered across by at least a few users. You can remove or just not connect the wires to the relay coil that would normally go to the RAMPS/RUMBA/etc electronics.
04-11-2016, 08:53 PM #3
- Jul 2014
- 305
04-11-2016, 09:07 PM #4
Yep, you can just remove them. Those wires would be the way the electronics would energize the relay coil to close the switch contacts. By jumpering across the switch contacts you no longer need to energize the relay coil, so the wires aren't needed. No need to jumper across the coil connections.
04-11-2016, 09:08 PM #5
- Jul 2014
- 305
