Thread: Cant connect to Rumba
04-10-2016, 08:38 PM #1
- Dec 2014
- Canada
- 498
Im running a Rumba board, I cannot seem to connect to Simplify3d machine control to the board. I have no issues connecting via usb from the Arduino IDE and the board shows up properly on Com3 on windows 10 64.
When i try to connect using simplify3d machine control on com3 it doesnt connect. I have tried all baud rates, tried other cables. but it flashes firmware fine. so that should make any difference.
also doesnt work with Printrun interface
Running marlin 1.1 RC4
04-11-2016, 12:28 PM #2
- Apr 2015
- Lakeport, CA.
- 174
Since you're running with a Windows machine, perhaps my comments don't apply, but...
I use Pronterface on OS/X, and I have a RUMBA. Also like you, Arduino worked fine going from Mac to RUMBA. And like you..., I couldn't get Pronterface to talk to the RUMBA. Baud settings on the Mac side made no difference.
So..., I set the baud on the firmware side, in Configuration.h:
#define BAUDRATE 115200
re-installed the firmware, and Pronterface has worked ever since.
HTH.
04-11-2016, 01:44 PM #3
- Dec 2014
- Canada
- 498
i had mine originally set to 115200 already.
also tried on a 2nd machine. and same issue.. using simplify3d or pronterface.. cant connect
04-12-2016, 10:46 PM #4
- Dec 2014
- Canada
- 498
Ok so i tried Repetier and it installed fine and I am able to connect fine with simplify 3d
reinstalled a fresh version of Marlin 1.1 RC3, same issue as RC4 & RC5 cant connect
I notice that when i try to connect with simplify3d the rumba resets.
if i turn off the startup command in simplify3d i am able to connect but it doesnt respond to GCode commands
04-15-2016, 07:44 PM #5
- Dec 2014
- Canada
- 498
finally figured out the problem. in Marlin I had set the Serial Port to 3 thinking it was the same thing as the com port for my computer.
Once i switched it back to its defauly 0, it connected fine.
