Results 1 to 10 of 23
Thread: Printrbot Metal Plus : prints
07-09-2015, 03:57 AM #1
Things that happened the last few months.
07-09-2015, 05:37 AM #2
Would love to know how you get your nozzles from not drooling during dual extrusions.
Also, is that delamination on your traffic cones?
07-09-2015, 07:33 AM #3
As to that, it is a very basic but efficient technique : I use the "change tool scripts" to turn down the unused hot end while powering the new one.
No heat = no oozing.
No heat = smaller hot end (no thermal expansion) => no idle head colliding with the build.
Admittedly it is an efficient way to do things only in when the 2 colors are completely on different planes. It still works otherwise but it increases print time like hell.
So when I transition from white (hot end 0) :
M104 S0 T0
M109 S200 T1
And then the reverse
M104 S0 T1
M109 S200 T0
I usually add a little more text to move the head away from the build first and then bring it back (I think it uses G91/G92 and move commands).
Unfortunately correct, but this is entirely on my design. I wanted to overdo it and added a "radius chamfer" at the bottom that had a horizontal tangent... therefore it didn't work well since the first layer had nothing to support it. Print didn't fail though so I'll keep it once I fill the hole with compound.
07-09-2015, 10:31 AM #4
I have read about this technique, how much longer are we talking?
I want to do some dual extrusion but I will have two colours on the same layer so I think this would make the print incredibly long. Not to mention the PITA of printing hot ABS into sections of already cooled ABS... warp city...
07-09-2015, 10:33 AM #5
Oh yeah... do you add all that code manually or does the software do it automatically?
07-09-2015, 01:42 PM #6
S3D adds the code on its own if you put it in the tool change script.
For my machine it takes about 3 mins to bring the hot end to temp. So if it is only a couple times per print ... No sweat. If you do it at every layer... Better be patient.
Oh and i only do this with pla and pet... Never tried ABS so far.
07-29-2015, 01:46 AM #7
A couple more things I made recently :
1/ a replacement for our waterski fin.
2/ a repair for a colleague : fits better than original !
08-24-2015, 09:00 AM #8
Sorry for the newbie question... but waterski fin in PLA? Does that not degrade in saltwater? I thought that ABS was better for parts that would be exposed to the elements.
08-24-2015, 09:34 AM #9
08-24-2015, 09:57 AM #10
Got it. Thank you for the clarification.
