Results 1 to 10 of 22
Thread: Filament refusing to feed.
03-18-2016, 03:42 PM #20
Yes, I removed the very loud 40mm fan at Mobo and replaced it with a 120mm fan,
hung below the Mobo.
(used plastic tie-wraps to suspend there, since not much there to make a solid attachment,
after removing the plywood cover-plate, that is not needed)
Very quiet that way and larger fan cools Mobo better !
I also printed 4 shock-mount Feet, that raises printer up from table about 2 inches ,
which gives more space, for that 120mm replacement fan, under printer.
(file for Feet can be found at thingiverse.com)
Note: also added a removable Dust-Filter on Fan,
which the 40mm fan did Not haveLast edited by EagleSeven; 03-18-2016 at 04:14 PM.
