Results 1 to 5 of 5
Thread: Microstepping
Hybrid View
01-21-2016, 11:34 PM #1
- Oct 2014
- 134
Microstepping
Since I have come into some 8825 drivers capable of 1/32 steps I was wondering if the finer steps could give me less vibration and noise, and possibly improved resolution? I am aware of the necessary changes to Marlin to accommodate the 1/32 steps instead of the 1/16 steps should this be a worthwhile endeavor.
01-21-2016, 11:40 PM #2
- Jun 2014
- Burnley, UK
- 1,662
No. Do a bit of arithmetic with the numbers and you will see that 32 V 16 is not even worth considering. On top of the theoretical part you should also consider that the cheap steppers found in most 3D printers will not even accurately do 16 steps and are at their best with half step or full step.
01-23-2016, 05:15 PM #3
There likely isn't any advantage in terms of resolution, and 1/16 is pretty smooth with most steppers anyway.
Make sure you're using stepper motors with very low inductance if you're having trouble with noise and vibration. Inductance per coil should ideally be under 3uH for a 12V power supply. If your inductance is much more than that, you're probably already having trouble getting the current to rise fast enough in the coil to do 1/16 microsteps. This was a problem with motors that MakerFarm was shipping in early 2014, but I think the later motors are better.
01-23-2016, 05:53 PM #4
- Oct 2014
- 134
03-19-2020, 11:55 PM #5
- Mar 2020
Qidi X Plus 3 Paper thin first...
05-27-2024, 01:15 AM in General 3D Printing Discussion
