Results 1 to 10 of 10
Thread: Pegasus vs. Form1
03-02-2014, 04:06 PM #1
I printed an Eiffel Tower on my Form 1 I'm not sure I have the same model as they're using but I'll try it again eventually with the same model to see.
But on the one I printed the one rail fell off because the supports were thinner than hair, but the rest is amazing.
I printed directly on the base without using any supports. The upper braces are not all filled as in their pic, and there is no spire damage.
I printed on the .05mm setting, I haven't had any luck with the higher resolution setting, they'll have to develop a resin that works better at the higher res setting.
I like that they will have manual support generation like the B9 Creator does, that's one thing I keep hoping Formlabs will add soon!
-Edit- yeah just looked and I had used the original model from GrabCAD, I will use the Thingiverse-Fixed model next time!Last edited by My Thing in 3D; 03-02-2014 at 04:12 PM.
