Results 1 to 10 of 32
Thread: R.I.P. Power Supply
12-10-2015, 11:01 AM #1
Every power supply must have some kind of fuse for protection. Whether its internal or external. If you open it up I'm sure you could find a fuse. Open the power supply and send a picture here on the forum and we can help identify it for you.
12-10-2015, 09:12 PM #2
- Aug 2015
- Vail, CO, USA
- 36
Let me know if anything is amiss.
I assume you're using one of the usual 12V 30-amps or so switching power supplies that fit the mounting hole pattern on the MakerFarm printers.
If the fuse is good or burns open again after replacement, I'd look for a new power supply.
P.S. Yes the fuse is completely intact if you can't tell from the tiny picLast edited by spaceorange12; 12-10-2015 at 09:13 PM. Reason: Clarification
12-11-2015, 07:16 AM #3
I lucked into a used power supply, so I don't have a vetted source to offer. Someone else might. Meanwell doesn't appear to be publishing any "how to identify a fake Meanwell" info, so I can't offer that either.
There have been a few threads where options have been discussed. Some have done well with the low cost knockoffs - you just have to accept the YMMV factor. Your range of replacement options depends on whether you want the power supply to mount on the printer frame. If not, some have used an ATX-type power supply. This thread mentions a server power supply that has been adapted for free-standing use - http://3dprintboard.com/showthread.p...nt-Requirement.
40 amps would put you into a 500 watt or larger power supply. Just as another option, MakerFarm at least used to suggest using two power supplies on the larger printers, with one dedicated to the large heat bed on those printers. A smaller one can be used to power the electronics, motor, and extruder heater.
