Thread: Ridged prints from Prusa I3
10-06-2015, 07:54 PM #4
Hi! It seems like this is an extrusion problem. Try to troubleshoot it with these tips:
- Check the gears If that is the case check the extruder pinion and make sure the gear and pinion are not stripped. If the pinion is spinning independently of the motor there is a problem.
- check the motor driver make sure the motor driver is turned up high enough to extruder the plastic
- check the filament make sure you check to make sure the hobbed bolt is not running in a divot. Also make sure you are using good filament
- check heating 180 , depending on the material, may not be high enough. you may want to go ahead and check some higher temps.
- lastly if none of these were the issue take the nozzle appart and clean it.
Hope this helps!
