Results 1 to 6 of 6
Thread: Print Quality
Hybrid View
10-05-2015, 08:24 PM #1
- Dec 2014
- Canada
- 498
Print Quality
I have installed the Aluminum bed, made myself a custom Alum Plate X gantry for the hotend. and installed PID heating on the print surface
im printing with PETG using a E3D v6 .4, using .20 layers.. so far im very pleased with the quality of my prints.
I love PETG its been the best plastic so far.. better then PLA and ABS.
I still need to play with the retract settings as i do get the occasional corner blob
any recommendations on how to improve even more would be appreciated
BTW near the top you can see a banding effect.. there is a solid layer every 20 layers for structure
10-08-2015, 05:48 AM #2
- Jun 2014
- 349
Does the band height correspond to a certain number of Z rod rotations?
10-08-2015, 09:57 AM #3
- Dec 2014
- Canada
- 498
layer height is set by layer setting in slicer. Z rod rotations is controlled in firmware by a set number of steps for the stepper/rod used
The Banding was preset every 40 layers to do a stronger layer.
10-12-2015, 02:08 AM #4
- Jun 2014
- 349
Every 20 or every 40? And is the band on those layers? If so then something with the solid layer is causing it.
Knowing black PETG, and knowing that lower temps reduce the gloss, I'd say that the solid layers are extruding much more and the nozzle is not keeping the temp up, thus causing less gloss. So you could try to increase temps overall, or check to make sure the nozzle stays at temp on those layers, or slow down speed which allows the nozzle to keep the temp up, or of course stop using solid layers.
10-13-2015, 09:34 AM #5
- Dec 2014
- 28
10-13-2015, 10:02 AM #6
- Dec 2014
- Canada
- 498
New to 3d printing looking for...
05-20-2024, 12:56 AM in Tips, Tricks and Tech Help
